Allow separate billing rates for members on the same project
Toggl Track
Topic content
Allow different members to have different billing rates. I charge more per hour than some of my subcontractors or people I white label projects for, but when I share a project with the contractor it is the project, not the people, that have an hourly rate.
The inverse is also true; sometimes I am charging less.
A use case example from my own agency is when I work with a web dev. I’m a copywriter and marketer so do very different work than the dev. Since it’s usually my client and project, I charge $x.xx/ hour. The dev charges $y.yy per hour.
To make invoicing easier, I invite the web dev to the project. This is because I submit reports to the client with their invoice so they can see exactly what thay paid for. But the report now shows both of us charging the same rate which if course is not true.
This also forces me to do manual billing and generate a non-Toggle report for the client, at which point I am uncertain what I’m even paying Toggl for.
This is a great use case, and the need for per-member billing rates on a shared project is a real gap. In Toggl Track, billable rates can be set at the workspace, project, or individual time-entry level, but the current structure ties a rate to the project rather than to the specific person logging time within it, which is exactly the friction you’re describing.
The closest workaround available today would be to set rates at the individual time-entry level, overriding the project rate manually for entries that belong to your contractor. It’s not automatic, but it does let the correct rate show up in reports without requiring you to leave Toggl Track entirely.
Another approach some people use is to create separate projects for each person’s work within the same client engagement, each with its own rate. The trade-off is that it splits what is logically one project into several, which may not suit how you want your reports to look.
Neither of these is as clean as what you’re asking for. Per-member rates on a shared project is not currently available as an automatic feature. I’ll make sure this feedback reaches the product team, as it’s a genuinely useful scenario for anyone running an agency or collaborating with contractors at different rates.
