Custom daily interval for reports
Toggl 2.0
Topic content
In the new version, I can’t select a custom time period for the report. For my work, I usually set the period from the 25th to the 25th of each month. I can’t do that now, and I’m panicking about how to track my time.
Custom date ranges that run from a specific day of one month to the same day of the next (like the 25th to the 25th) are not currently available as a rolling interval in Toggl’s reports. The date range options are limited to preset rolling periods or fixed date ranges.
As a workaround, you can use a fixed date range and manually set the start and end dates each time (e.g. the 25th of one month to the 24th of the next). This won’t roll forward automatically, but it will let you see exactly the period you need. You can save this as a saved view, though you would need to update the dates each month.
This is a great idea for a custom rolling interval option, and I’ll make sure to pass this feedback along to the product team.
