Toggl
Topic content
Is it possible to import an excel file from another time tracking tool that I exported into Toggl? This way, it would be easier to change from another tool to Toggl 2.0 or Toggl Track. I only see a PDF export in Toggl Track, and a PDF/CSV/XLS export in Toggl 2.0, but no importing options.
Yes, this is possible in Toggl. The Universal CSV Importer lets workspace admins upload a CSV file from another tool and map its columns to Toggl fields, covering clients, projects, tasks, tags, members, and time entries. If your other tool exports to Excel (XLS/XLSX), you can save or convert that file to CSV format first, then use the importer.
You can find full details on how to set it up here: Universal CSV Importer
There is also a dedicated importer if you are coming specifically from Toggl Track or Toggl Plan, which you can read about here: Importing data from Toggl Plan and Toggl Track to Toggl
