Incorrect Timezone
Recently, Alberta, Canada removed daylight savings. This means America/Edmonton should currently be UTC-6 when currently the UI has it still listed as UTC-7.
This looks like a bug with how Toggl Track is displaying the UTC offset for the America/Edmonton timezone following Alberta’s decision to stop observing daylight saving time. The timezone identifier itself (America/Edmonton) is correct, but the displayed UTC offset appears not to have been updated to reflect the change.
This is something the Toggl Track team would need to fix on their end by updating the timezone offset data in the UI. I’ll make sure this feedback and the reported discrepancy get passed along to the product team.
In the meantime, if the incorrect display is causing actual timing issues with your entries or reports, you could try selecting a timezone that currently sits at UTC-6 as a workaround, though that’s not ideal given the timezone name would then be inaccurate.
I’m in BC and the same is happening to me. Even if I try the workaround suggested (changing my UTC timezone) toggl stubbornly refuses to match my current time. It is behind by an hour, so if I try to make entries that are current, it gets confused and selects yesterday making me reenter times at least twice and correct my running time. I’ve tried all suggestions in threads and posts, including clearing my cache and trying incognito.
I’m in the same boat, @Reb-L - my Google Calendar integration is stubbornly refusing to show the correct time, despite the time zone matching what’s in my Google Cal (UTC -7, America/Vancouver) so all my tracked entries are an hour off. Argh!
Hey there :slight_smile:
If you’re in BC, Canada, and your Toggl account timezone is set to Los Angeles, then this is almost certainly the cause.
LA moved back to UTC−8 on Nov 1, but BC stopped changing clocks and now stays on UTC−7 all year, so you should change the timezone in Account Settings to Vancouver instead of any “Pacific Time” option.
If the Vancouver option still shows UTC−8 after that, then your browser or Operating System timezone data is most likely out of date, and you should update both (try turning the time setting on your device so that it is not “Automatic”, then completely close your browser, and then open a new browser with Toggl) :slight_smile:
If you’re experiencing this issue and are from a different area, please let us know :folded_hands:
I think everyone in the thread has acknowledged that we’re using the correct America/Edmonton or America/Vancouver.
For my part, I don’t think this is a browser or operating system issue. Both my in-browser clock and operating system correctly show the time and UTC-6 time for America/Edmonton. Toggl is the only site that’s still showing America/Edmonton as UTC-7.
