Monthly report by tags
Toggl Track
Topic content
I’m the only person using using the software. I record things with tags. Starting early October I couldn’t produce a monthly report which showed the total hours I’d done for each tag (which is what my staffing committee requires me to do). Is this no longer possible? If it is possible, how to do it please. Thanks, Jools
Grouping a report by tag is still possible in Toggl Track. Here’s how to get your monthly tag totals:
Go to Reports and open the Summary Report. From there you can set the date range to the month you need, then group the results by Tag. This will give you the total hours for each tag across that period, which sounds like exactly what your staffing committee needs.
If you are not seeing tags as a grouping or filter option, it is worth checking that the time entries you recorded actually have tags assigned, as untagged entries will not appear under any tag grouping.
You can also use the filters in reports to narrow things down further if needed. The filters available include Tag, and you can combine them with date ranges. More detail on filtering options is at Using Filters in Toggl Track Reports | Toggl Knowledge Base
If the Summary Report layout has changed and things look different from what you remember, the grouping controls are usually near the top of the report view. Try looking for a “Group by” selector and switching it to Tag.
Sorry but that is not what I want. You have given me details on how to get a report for one specific tag. I used to be able to do it for all tags, though I can’t remember how. Things changed in early October, I suspect when things were changed at your end. I’d really like a human to help with this but I can’t see how to “tag support” in my reply.
