Post DST Change: Time Entries Rendering with Old Timezone
Toggl
Daylight saving time transitions can definitely cause some confusing display behavior in Toggl.
The core reason is that every time entry permanently stores the timezone it was originally tracked in. When DST shifts your local offset, entries logged before the change keep their original timezone, while new entries are logged in the updated offset. Toggl does not retroactively adjust entries when the clock changes, so you may see entries that appear to sit at unexpected times or on different calendar days than you expect.
A few things that may help:
If you haven’t already, confirm your account timezone is correctly set for your current offset. Go to Settings → Preferences → Time Preferences and check the Account timezone dropdown. This won’t rewrite past entries, but it ensures new entries and day boundaries are calculated correctly going forward.
For reports, if you are a Workspace Admin, Team Lead, or Project Manager, you can turn on “View reported data in my time” in the Reports settings. This will show Summary and Time Logs reports converted to your personal account timezone, which can make pre- and post-DST entries easier to compare. Note that Workload, Utilization, and Profitability reports always display entries in the timezone they were originally tracked in, regardless of this setting.
For more detail on how Toggl handles timezones, this article covers the full picture: Timezones in Toggl
