Projects are private
Toggl 2.0
Topic content
I have many projects that are imported from Toggle Track. And i want to rename some of the projects, but when im on the Projects menu all the projects in the list is grayed out. If i click the dot-menu to the right, i can click “Make public” .. then the project lights up and its possible to rename it.
The problem is that i have alot of projects and would take a long time to “Make public” on each of them.
Any suggestions?
I had the same problem. What I did is go into the previous Toggl version in the browser and then I selected all the projects and made them public one page at a time, instead of one project at a time.
Thank you! That solved it! :slight_smile:
