Recurring projects and templates: How do you track time against them?
Hi everyone,
We’re currently setting up recurring monthly projects in Toggl Track and finding the functionality a little limiting.
Ideally, we’d like to create a project template with predefined tasks, time estimates and budgets, then use that template for recurring monthly projects.
A few things we’re struggling with:
  • We can’t seem to allocate or track time directly against project templates.
  • It’s unclear how to link recurring projects to templates so the tasks and estimates carry across automatically.
  • Templates appear alongside our other projects, which makes the project list quite cluttered.
  • We’d like to track time against each month’s project while keeping the original template intact for future periods.
Is there a way to achieve this using recurring projects and templates, or is there a better setup you’d recommend?
Thanks in advance!
Toggl Track does not have a native project template feature or a way to automatically carry tasks and estimates from one project into a new recurring one. Here is how most teams work around this:
Manual duplication approach
The most common workaround is to manually recreate the project each month, copying your standard set of tasks and estimates. It is tedious but keeps each month’s data cleanly separated. Toggl Track’s API (at api.track.toggl.com) can help here if you are comfortable scripting - you could write a script that creates a new project with predefined tasks and estimates at the start of each month, using the same values each time.
Clutter in the project list
There is no built-in way to flag a project as a “template” and hide it from the main list. If you do keep a reference project to copy from, one approach teams use is naming it with a prefix like “_TEMPLATE” so it sorts separately and is visually distinct, though it will still appear in the list.
Keeping templates intact
Since there is no link between projects, tracking time against each month’s project does leave your reference project untouched - as long as you do not log time entries against it. You would just need discipline to always start a fresh project for each period.
Fixed fee and budget tracking
Toggl Track does support adding a fixed fee or time budget per project, so each monthly project can have its own budget set independently.
This is genuinely a gap in Toggl Track’s current feature set, and recurring project templates with automatic task carry-over would be a useful addition. I’ll make sure this feedback reaches the product team.
