Recurring projects missing from Toggl 2.0 time-entry picker
Toggl
Topic content
Since moving from Toggl Track to Toggl 2.0, I can’t select either of my monthly recurring projects when logging time in the web app.
In Timer → Log time → Project or task, other projects appear, but the recurring projects don’t—even when I search for them. Their October periods are current and active, I’m shown as Project Manager, and the period page shows time already logged. I can also log time to the current periods through the Toggl MCP server; those entries appear in the projects.
I expected to be able to select the current recurring period just like any other project. Has anyone else encountered this or found a workaround? I can share screenshots of the picker and project period.
This sounds like a frustrating issue, especially since the time entries are going through correctly via the MCP server and showing up in the project periods.
The documentation for recurring projects in Toggl covers how to set them up and configure cadence, budget, and rollover, but it does not describe any known limitation that would cause recurring project periods to be hidden from the time-entry picker in the web app. So I can’t confirm whether this is expected behavior or a bug.
A few things worth trying as workarounds:
Since logging time through the Toggl MCP server works, that path is available to you in the meantime. You might also try logging time directly from within the project period page itself, if the period view offers a way to add time entries there, rather than going through the Timer → Log time flow.
It may also be worth checking whether the recurring project periods appear if you browse by project rather than searching, in case the search index is not picking them up for recurring periods.
If other team members with Project Manager or Member roles on those projects have the same issue, that would help narrow down whether it is tied to the recurring structure specifically or something about the picker more broadly.
The behavior you are describing - active periods visible elsewhere but absent from the picker - does look like something worth having the Toggl team look at. I’ll pass this along as a bug report on your behalf, and sharing screenshots as you mentioned would be helpful if you post them here.
