Toggl Track
Topic content
If you select the project after filling in the description on all apps (phone, desktop and web browser) it deletes the description and you have to re-type the description. Given that the project selection bar is below the description field, to me at least it makes sense to type the description and then select the project, so this is annoying as all get out. This was not an issue prior to the upgrade.
Also, is there a way to clear or not have the list of “Previously used” since that populates both the project and the description? And also makes scrolling through projects to select the right one more cumbersome.
Thank you.
In case more clarity is needed, an example would be:
Type Descripiton [Bob’s Book | Research printers and publishers] → Scroll through projects to select them [Scroll scroll scroll more scroll through yesterday’s work on Bob’s book; ah, projects, select Bob’s Book] → Description (i.e. “Research printers and publishers”) is now gone, grrr → Re-type description. According to timer, 7-15 seconds wasted.
That does sound frustrating, and the behavior you’re describing - selecting a project clearing the description field - is not how it should work. This reads like a bug rather than intended behavior, especially since you mention it wasn’t happening before a recent update.
On your second question, clearing or hiding the “Previously used” suggestions list is not currently available in Toggl Track. That list auto-populates to help speed up entry creation, but there is no setting to disable or clear it.
A couple of workarounds that might help in the meantime:
- Try selecting the project first, then typing the description. Since the project field sits below the description field visually, this feels backwards, but it would avoid the clearing issue until a fix is in place.
- On the web app, you can also create or edit time entries from the Calendar view, which gives you a slightly different entry form that may behave differently.
The description-clearing issue is worth flagging, and I’ll pass this along to the product team. The “Previously used” list suppression idea is a good one too, and I’ll share that as well.
Having an AI respond (instead of a gainfully employed human who can enjoy the dignity of work and economic security) does not make me more amenable to the idea of continuing to use Toggl.
Yes, AI has a place, and certainly there are a plethora of use cases within a time tracking app. But offloading interactions with paying customers - who take time out of their human lives to help you improve a product that generates profit for you - to a robot is not that place.
Did Toggl get VC finding or something? What happened to the cool, independent little startup that solved time tracking for freelancers?
I’ll be looking into open source alternatives or at least companies that value supporting humans and labor integrity.
