Severe Privacy GDPR issues
Toggl
Topic content
Activities are tracked when browser tabs are in privacy mode, the user can’t remove activity or clear activities from desktop app, it’s a Severe issue about user privacy. Need to be fixed as soon as possible.
This is a serious concern worth addressing clearly.
The behavior you are describing relates to the Auto-Tracker feature in the Toggl desktop app, which reads the active window or browser tab to suggest time entries. For this to work, you explicitly grant Accessibility access to the app in your operating system’s settings. Without that permission, the app cannot read window or tab information at all.
If you want to stop the app from reading browser activity, including private/incognito tabs, you can revoke Accessibility access for Toggl in your system settings (on Mac, under System Settings > Privacy & Security > Accessibility; on Windows, this is managed through the app’s own permissions). Revoking this will disable Auto-Tracker, Smart Suggestions, and reminders, but the app will no longer read any window or tab data.
Regarding removing or clearing tracked activity suggestions, the Toggl desktop app help covers what can be managed locally. You can find more detail at Toggl Desktop App.
If you believe there is a broader data handling or GDPR compliance issue beyond the Auto-Tracker feature - for example, concerning how data is stored or processed on Toggl’s servers - that falls under Toggl’s privacy policy and data processing terms, which you can review on toggl.com directly.
