Toggl 2.0
Topic content
I want to use Toggl 2.0 for basic task tracking, time boxing, and Pomodoro timer. I used TogglTrack/Focus for a while in the past and ran into many inconsistencies. I thought Toggl 2.0 might work for me.
The desktop app gets the job done, though there is no mini timer mode like previous Toggl. On the iOS app, where I’ll be using it most, there does not appear to be a way to set the timer into Pomodoro mode. I’ll not be using it right now for just this reason. There are probably other differences.
Timer syncing takes a long time to mobile, if it works at all. If I start or stop a timer on mobile, it is reflected quickly on desktop. If I do the same in the desktop interface, mobile seems to never update until I go to tasks and refresh.
I hope they can get this worked out. These are similar to inconsistencies/frustrations I ran into in the past with Toggl.
