Your first feedback about Toggl 2.0
Hi! The tool is looking great — thank you so much for your work! I have some feedback and a couple of questions I wanted to share. I’m a long-time Toggl Track user but only started using Toggl Focus a few days ago, so it’s possible I’m still missing something. In that case, apologies in advance!
  1. I’m using the “Both” calendar view (which shows both logged and scheduled tasks on the same page). While using this view, I sometimes accidentally assign a task from the “Tasks” pane to the “logged” section (on the left section in each column) instead of the “scheduled” section (on the right section in each column), even though I meant to schedule it. I drag a task from the “Tasks” pane to the calendar, but since the separator of “logged” and “schedule” sections is hard to see (I think it’s too thin and too light in color), it’s really easy to accidentally drag it into the unwanted sections. It’s more so when I’m using this platform in a split window (so the window size that I’m working with Toggle Focus is half the size of the full screen). In those cases, it seems the system doesn’t let me delete logged entries without deleting the task itself. Basically there’s only one option to delete the logged entries and that’s “delete the task”, which appears when I click the vertical three dot line in the top right corner of the logged entries. When I click this “delete the task” option, it removes the entire task from the Tasks pain. There are cases where I want to delete only the logged entry, not the task itself. Is there a way to do this? I hope I’m explaining the issue clearly enough to make sense.
  2. Is there a way to sync Toggl Track data with Toggl Focus? I know there’s an “import data” option in Toggl Focus, but it only imports Projects. Ideally, I’d like to sync all recorded data from Toggl Track to Toggl Focus for better management. Since it’s still 2025, I’d like to see all my 2025 data in one place, and right now Toggl Track and Toggl Focus feel like completely separate platforms.
Hey @Sayuri_Ishiwata, thanks for taking the time to share your feedback, I’ll share it with our team!
To delete a time log, you can right-click on it from the My Time view and click on “Delete time log” or open the task and select the same option:
We will be making improvements on the Import functionality in the near future, so please stay tuned for updates. :slight_smile:
Hi @Chris1, thanks for reporting, this should now be fixed!
@Rumi - any update on fixing the reports? Currently experiencing (at least) 3 problems -
  • a significant number of entries classed as “Without client” despite every project/task having a client assigned
  • the occasional task showing as no project, even though it is clearly assigned to a project
  • Reports seem to lag 2.5 days before showing all time entries.
Considering this is now a paid for platform the reporting should be working accurately and reliably.
And again I’d like to ask for project archiving to be implemented
ta
Martin
Hi Martin, I will send you a direct message to ask for your workspace and user details to be able to understand the issue better
Thanks Rumi; working as expected now.
Hi,
What I really need are improvements to the Export functionality of logged time. This is the CSV Export function of the Reports menu.
For billing purposes, I need the each logged time entry (not just a summary), including at least the date and duration. Ideally, the export would also include start/stop date/time data.
As it works now, I cannot use Focus because I will not manually re-enter all my project, task, and time information into Toggl Track nor my billing software. So, I’ll stick with Toggle Track because Toggle Focus does allow the level of detail I require.
If an update to the CSV Export feature is planned, might you have an implementation date that you can share?
Hi, I would really appreciate Widgets for the IOS App which allow me to view and log my tasks from the homescreen.
Hi @KevinP, this will be part of the Detailed Report, which our team will be working on early next year - so stay tuned. :slight_smile:
Thanks @samuelrd28, shared this with the team
Really good in general. Need the ability to edit time entry if I leave a timer running. If there’s a way to do it, it’s not very obvious
Edit I found how to do it. I think where it’s located inside the the task is good. And I see now how to do it on the timer’s page as well which is where I wanted to do it. Perhaps the initial default for view should be “Both” which will make it easier when first using the tool to see your time entries here
Hi, I’ve been a long-time Toggl Track user. I’m struggling to understand why there isn’t live sync with Track. Is this intended more as a “Track 2.0” that we would need to move our team to?
For context, we already have a team actively working in Track. While Focus could be a good idea, I’m having difficulty seeing how it would work seamlessly for us unless there is live synchronization, or unless we fully migrate to Focus.
Thanks.
I’m also struggling with this. I need features like billable hours, profitability etc. What I like about Focus is the ability to track my time in a more fine grained way with subtasks and descriptions for tasks so I have a much more detailed view of the work I did for the client. Currently it looks like I’ll need both but there is no integration between them besides the import from Track into Focus or CSV. If Focus gets the Track features that would be great but if they are going to be two different products going forward can we get two way sync?
Hi,
Thanks for the app and for this great community!
I’ve been using Focus for a couple of months and have encountered some issues. Maybe someone has ideas how to solve them.
I’ve used Toggl Track a few times in the past. I also tried Toggl Plan but didn’t fully dive into it. When I finally needed a project management tool, I came back to Toggl Plan which was in transition to Focus, so I switched to it from the beginning. I love it!
Some issues I noticed:
  • Timeline view: weekends are preset to include Saturdays and Sundays. But if I turn that off, they disappear completely from the view. This happens even though my settings have the week starting on Sunday.
  • 5-day view shows Mon-Fr by default, instead of the next 5 days, as 3-day does.
  • “Unarchive tasks” didn’t work.
  • I’ve noticed a date error in the Android app. When I set a ‘From-To’ range for a new task, the calendar shifts by one day (see screenshot).
Something that I would be happy to hear how to solve:
  • I imported several projects from Toggl Plan that I no longer need active. I don’t need them now and want to archive them. But don’t see this option for projects, only delete them completely.
  • If I don’t explicitly assign a task, it doesn’t appear in the Task pane in My Time view. Since I use Focus alone it’s annoying that I still need to assign every task. I didn’t find how to set default asignee or display all the task on the pane.
  • I have my account registered on my personal email and added a work email as a member. But everything became split or filtered. How can I disable member-based filtering and splitting?
  • I love the logged periods feature in the card view! It would be great if you can add an option to display logged periods in reverse chronological order, so that having the newest entries at the top.
  • Is there a way to rearrange subtasks between parent tasks?
  • All tasks in My time view are displayed as a plain list. It would be helpful to have an option to group or arrange them by parent task or project.
Sorry, I just noticed the reply to my feedback. It looks like the issue was resolved; I can see the subtasks now. When I provided the feedback, I couldn’t see the subtasks anywhere, not even the parent task’s details. After providing the feedback, I went back to solely using Track; at the time Focus wasn’t useable for my needs. Thanks for the follow up!
Hi really like the concept. I’ve only been using track up to now and planning in other tools but being able to integrate both would be very useful (just tracking my own work). Apologies if these exist already and I have missed them
Few things I’ve noticed that would be nice to have
  • · Ability to duplicate projects (and all tasks contained in project)
  • · Ability to collapse sub-tasks or filter out sub tasks in views (or see as a hierarcy)
  • · Ability to archive or delete workspaces
  • · Option to manage tags and clients on side menu (add, delete, overview of all tags and clients) Also customisable colours for projects (colours are currently not very distinct)
  • · Add due date to tasks as well as start and end tasks (so that they don’t end up in the calendar view until you plan to do them, but you still have an idea when they are needed by)
  • · Colour code the cards on the board according to project (use the project colour as a fill colour)
Two changes that I don’t like / don’t work.
With the new pop up box that appears when you click a task in task view, the start button doesn’t start the timer. Need to open using “more details” to get the old view.
Is there a way to change the actual time in reports back the xx:yy:zz format rather than 2h02m15s ? Much easier to work with in Excel. I’ve changed all the time settings I can find to 00:00:00 format but reports still use hms.
Feedback from a longtime Toggl Track user on Focus
I’ve been using Toggl Track for many years and it’s been a core part of how I work. When I found Focus, I was genuinely excited. The idea of combining time blocking and time tracking on the same screen, with Google Calendar integration and a Kanban view organized around projects, is exactly what I’ve been looking for. I want to see this product succeed, which is why I’m taking the time to write this up.
I’ve run into several issues, both in the product itself and in the demo/documentation. Sharing them here in hopes they’re useful to the team.
The Storylane demo is out of date
The demo at Toggl Focus Demo | Solo Users seems to be out of sync with the current product in a few places:
  • Part 2, Step 4 (solo user flow): The “Show” pull-down highlighted in this step doesn’t exist in the actual product.
  • Part 2, Step 5: The settings shown in the Personal Details section don’t appear in the actual product.
  • Part 3, Slide 7: Points to a time tracking option in the Plan menu that isn’t there.
  • Part 3, Step 12: Shows a “Day Complete” option that also doesn’t exist in the product.
The demo is the only documentation I could find, so having it reference features that aren’t there makes onboarding pretty confusing.
The Google Calendar auto-tracking setting is hard to find and the default behavior is surprising
The setting to control auto-tracking of Google Calendar events is buried under the gear icon in the top right, and it’s just labeled “Calendar events” with no indication of what it actually does. I’d expect it to be better labeled and to find something like this in the main admin settings panel, but it’s not there.
The bigger issue is the default behavior: all Google Calendar events get automatically marked as completed and logged. That’s almost never what someone wants when they first connect their calendar. Most events are plans, not confirmed completions. And if you want to undo it, the process is really tedious: you have to delete each day’s logged tasks, then click the scheduled item once to unmark it, then click it again if you actually did complete it. A lot of friction just to clean up a default state that probably shouldn’t exist.
Crossed-out items on the calendar aren’t intuitive
It took me a while to figure out that struck-through text means a task is completed. I eventually got there, but a tooltip or slightly more conventional visual treatment would go a long way.
Can’t log time on weekends
The system won’t let me log time on Saturday or Sunday, and I can’t find a setting to change this.This is a real limitation. Or maybe I’m just missing something. I would really appreciate it if someone could point me in the right direction.
Hi,
I still feel like the integration with Track should be smoother. If I accidentally track smtg from Track, it is hard to merge it back with the appropriate task on 2.0. There is also this unsightly duplication of projects “from Track” and “in 2.0”. On the other hand, the tracking isn’t as straight forward in 2.0; for example, on the mobile app, the widgets are still missing (which were key to start quickly tracking), same with the Pomodoro feature of Track (it should be integrated directly into 2.0.
Hello. I like Toggl 2.0 very much i wanted to report some bugs and issues.
  • A couple days ago it started lagging in the timer view. A lot. The more I am zoomed in in the view the longer it takes to load and it just freezes.
  • I created 3 recurring projects and now i cannot close the period and start a new one.
