Your first feedback about Toggl 2.0
I’m finding this who UX and UI to be very cluttered and confusing.
I don’t understand why I have duplicate projects that have (plan) after them.
Other projects have an odd number in front of them.
And I was very excited about tasks and sub-tasks as I’m a HUGE lister (the inability to start tracking Toggl directly from Habitica was devastating to me). But if you click the subtask, it shows up without a main description, which I assumed would be the main/parent task. So you have to fill that out, which basically negates the convenience of tracking directly from the subtask.
Also, having each subtask show up as it’s own thing on the right-hand side is cluttered. Wouldn’t it make more sense to have each task listed and then maybe with an arrow that you click for the sub-tasks? Then you can can just click track next to the that sub-task.
I understand this could be user error on my part, but I’ve always loved and recommended Toggl to my fellow ghostwriters and freelancers. I’m a huge planner and love dragging tasks to the calendar for the next day. But at this point it feels far, far too granular for my needs. I’ll give it another two months - I’ve been a Toggl for years and would hate to leave it - but I hope some of these things are addressed.
Is there a way to disable tracking overlapping entries? like as of now, it’s tracking my daily hours to even 33.
What Toggl 2.0 needs to do right now:
Toggl 2.0 Windows desktop app:
  1. A floating timer is desperately needed
  2. Time tracking should allow pause function that you can pick up where you left. Pause a tracker, then let it sit at 40 minutes, then run another tracker, then come back to the same tracker and start from 40 minutes onward.
  3. I have still yet to understand the purpose of a time entry title/description, and a task, that appear simultaneously on a time entry, yet the task isn’t the main title, but the description is. The UI is designed in such a misleading way. I honestly have no idea how to properly use this app till this point.
  4. Why every time when the idle time logs a new time entry, a “new task” is automatically added???
Toggle 2.0 iOS app:
  1. The UI on iPhone SE 3 is not fully stretched to the full screen. There is empty space at the bottom.
  2. Not to mention dark mode and light mode can’t automatically switch.
  3. You should have an option to switch day view from 1 to 3 days as a dedicated button on the top right of the calendar
  4. iOS app misses some features from the desktop app, then the desktop app misses some features from the iOS app
Toggl Track is still usable. Then there is Toggl 2.0. Everything is so chaotic here. Naming changes all the time. Then the features aren’t consistent across apps (desktop and iOS have completely different features.) It’s so chaotic.
I agree. Generally chaotic af.
That’s easily fixable. Just drag the Toggl 2.0 shortcut icon to the start up folder of Windows 11.
2.0 : Doesn’t seem to sync with my windows widget. When I click on “Explore on the web app” and then Track the current activity is blank, in the old toggl it was populated with what I was tracking on the desktop widget. List View- can’t find to option to list all individual task instead of the grouped tasks,
Hi Arnie, I had the same problem. Discovered on Google Play that there is another APP “Toggl: Track Time & Plan Work”. That one seems to sync in real time.
(I am just a user, no offical support)
Hi Rasa,
After 1 day of Toggle 2.0 :
  • I am missing a "simple " layout of the toggl 2.0 desktop app (just like the Toggl 1.0 windows app had)
  • concerning the toggl 2.0 andorid app
    a) Once installed its called Toggl 2.0 (versus Toggl Track), but in the play store it’s “Toggl: Track Time & Plan Work”. Why not naming it “Toggl 2.0: Track Time & Plan Work”. That would be much easier & clear (since version 1.0&2.0 do not sync in realtime)
    b) I do hope that the timer screen in de android APP (and desktop app) does not only show Last-This-Next week, but can also show “the latest” just like the old version where now i can see by default all my entries of the last 8 weeks
I really love the plan and track split on desktop. It is incredible. If mobile were the same style split(2 columns) it would be next level amazing!
Editing a project is broken in the list view. It’s still my preferred view as opposed to the calendar views since for short duration timeblocks, they aren’t easily viewable in the calendar.
It looks like Report links viewable by anyone was a feature that was removed from Toggl Track. Would love to have that back as it’s always been one of the most convenient features for me. Thank you!
I’ll be brutally honest, because that is what helps products become better. If you are going to charge people for exporting PDFs, I’m 1) going to create my own time-tracking app with AI and 2) provide a prompt/open-source version for others to use.
Your pricing is egregious.
This is my previous comment. This is what the iOS Toggl 2.0 app looks like on my iPhone SE 3:
You can see that the red circle is space that the app hasn’t fully utilized.
The new Windows update 1.6.1
Toggl stops auto tracking its own app anymore.
I set the tracking rule as “Toggl” exact phrase. However, right now when I am on the Toggl 2.0 UI, it simply does not track itself anymore. Before this update, it tracked itself, now, it doesn’t.
What is going on???
Hi Rasa,
Thanks for asking for feedback!
I’ve been testing Toggl 2.0 both on the Windows app and in the browser. I really like the idea of merging tracking and planning in one place, but a few UI/UX changes are currently making my day-to-day workflow pretty frustrating:
  • Colors are totally off on the timeline: I rely heavily on strict color coding to match Toggl with my other work tools. Right now, even though I pick exact HEX codes, the timeline automatically tweaks them. My yellow and gold projects end up looking like dark greenish/olive blocks. It would be awesome if we could just keep the exact colors we pick without automatic contrast adjustments.
  • Can’t see full project names: I use long project titles (Category - Start Date - Project Name - Deliverable). On the 2.0 timeline, these get cut off, and there’s no way to read the full name — even if I hover over the block or click on it. Adding a simple hover tooltip with the full title would be a lifesaver.
  • Idle time window feels downgraded: The old app gave us great choices when stepping away from the PC (like discarding idle time but keeping the timer running). The new window only has basic Save/Cancel options, which feels like a step back in convenience.
  • No live timer for the active task: When I’m running a timer, I need to see how long I’ve been working on that specific task in real-time. Right now, Toggl 2.0 only shows the total time after I stop it, which makes it hard to keep track of my focus blocks.
Hope this helps the team fine-tune the app. Looking forward to seeing where Toggl 2.0 goes!
Best,
Ihor
I think the new colors in Toggl 2.0 is a downgrade from the more calmer colors we had before. Now the labels are dark with black text.. very hard to read. Dark blue with black text!?
Love to have the old style back, or an option to switch to that style.
