Ability to set custom sounds
Dear Toggl Team!
I would love to have an option to customize sounds in the app especially for the pomodoro functionality. As an AuDHD person i have quite strong preferences towards sounds so having the ability to choose my own ticking sounds, timer start, timer end sounds would be awesome.
It’s quite the bummer to be limited to pre-existing sounds and not have the ability to choose custom sound from the device.
Hi @GingerNaTT thank you for this suggestion! Shared with the product team as a feature request :slight_smile:
Thank you very much!
So like with any App that has alarm functionality you can choose:
  • any predefined by the app developer
  • music/sounds that app knows from the phone (i guess android functionality to provide what folders are dedicated for such files or app just scanned for all sounds files)
  • ability to pick from device (allows to manually search for a sound file and choose it)
I’m most interested in the last one so i can pick a file from the device and have the app play it but the implementation is not as important as the functionality.
