“Approvals” Endpoints - DELETE Delete a timesheet setup
https://api.track.toggl.com/api/v9/workspaces/{workspace_id}/timesheet_setups/{setup_id}
Delete a timesheet setup for a given workspace.
extern crate tokio;extern crate serde_json;use reqwest::{Client};use reqwest::header::{CONTENT_TYPE};#[tokio::main]async fn main() -> Result<(), reqwest::Error> {  let client = Client::new().basic_auth("<email>", "<password>");  let json = client.request(Method::DELETE, "https://api.track.toggl.com/api/v9/workspaces/{workspace_id}/timesheet_setups/{setup_id}".to_string())  .header(CONTENT_TYPE, "application/json")  .send()  .await?  .json()  .await?;    println!("{:#?}", json);  Ok(())}
setup_id integer false Numeric ID of the timesheet setup
Successful operation.
Possible error messages:
  • Workspace not found
  • Invalid setup ID
  • Failed to delete timesheet setup, member has approved, rejected or submitted timesheets
402​
Approvals are a premium feature
User does not have access to this resource
