[Bug] Calendar Freezes After First Click (Requires Page Refresh)
Description: In the “My Time” calendar view, the UI completely stops responding to click events after the initial click. The first click functions normally, but any subsequent clicks on the calendar area do nothing. The only way to restore functionality is to refresh the page.
Steps to Reproduce:
  1. Navigate to the “My time” calendar view in Toggl Focus.
  2. Click anywhere on the calendar area (this first click interacts normally).
  3. Attempt to click a second time anywhere in the calendar area.
Actual Behavior: The second click (and all subsequent clicks) are ignored. The calendar UI becomes completely unresponsive to mouse clicks. A page refresh is required to regain functionality.
Expected Behavior: The calendar should allow continuous, sequential clicks and interactions without locking up or requiring a page refresh.
Environment / Troubleshooting Performed:
  • Browsers Tested: Firefox (LibreWolf) and Google Chrome (Stock)
  • Extensions: None (tested with zero extensions active to rule out ad-blocker or script conflicts)
  • Operating System: Fedora Linux 43 (KDE Plasma 6.6).
Thank you for the detailed bug report. This sounds like a frustrating issue where the calendar view becomes unresponsive after the first click.
Based on the information you’ve provided, this appears to be a technical issue that needs investigation. Since you’ve already done thorough troubleshooting across multiple browsers and confirmed it’s not related to extensions, the next step would be to have this looked into by the technical team.
In the meantime, as you’ve discovered, refreshing the page will restore functionality. If this issue persists and you find any additional patterns about when it occurs or what specific actions trigger it, that information would be helpful for diagnosis.
@farragoo, the issue should be resolved by now. Please let us know if you need help with anything else, or if you have any suggestions, feel free to post them in: Your first feedback about Toggl Focus - #139 by Ukthunderbunny74
:slight_smile:
~ Veljko
Thank you, it is! That’s great to see.
