Edit statuses only work for "in progress"
It’s cool that the “pipeline” view now seems to have edit buttons on the status columns, but I can only get edits to stick in the “in progress” column. If I make edits to the text or icon for the other columns, they seem to just revert back to the original text (“todo,” “blocked,” etc). Anyone else having this problem?
This sounds like it could be a bug with the pipeline view status column editing. However, this feature and the behavior you are describing are not something covered in the resources I have available, so I cannot confirm whether this is expected behavior or an issue specific to your account.
That said, what you are describing does sound like unintended behavior, and it would be worth checking if it happens across different browsers or after a page refresh to help narrow it down.
You may also want to see if other community members have run into the same thing, as someone may have found a workaround in the meantime.
