Feature request: Direct link/navigation to Project Info when clicking project name on task items
Toggl 2.0
Topic content
Feature Request: Direct link/navigation to Project Info when clicking project name on task items
Currently, on the task/to-do list, clicking a project’s name assigned to a task opens a dropdown menu (to change or reassign the project).
I’d like to request an option or direct link (e.g., Command/Ctrl + Click, or a dedicated icon/shortcut next to the name) that navigates directly to that project’s details overview instead.
While working through a to-do list, we often need to review overall project context. Having to manually search for or navigate to the project in the sidebar breaks the workflow. Allowing quick navigation directly from the task item would streamline task execution and save valuable time.
Thanks for considering this enhancement!
Yes, this feature would be very useful.
Thank you.
