Looking for the capability for rate discount. Could be based on percentage or pre-determined rate values. Add the option to automatically apply the discounts for reports and invoices, but also manual entry if required.
There can be multiple scenarios. The amount of hours that go over a threshold would use a different rate.
This should be available in the Starter, as a function of the Billable Rates feature.
