“Groups” Endpoints - PATCH Patch group
https://api.track.toggl.com/api/v9/organizations/{organization_id}/groups/{group_id}
Patches a group in the specified organization. Patches are applied individually.
extern crate tokio;extern crate serde_json;use reqwest::{Client};use reqwest::header::{CONTENT_TYPE};#[tokio::main]async fn main() -> Result<(), reqwest::Error> {  let client = Client::new().basic_auth("<email>", "<password>");  let json = client.request(Method::PATCH, "https://api.track.toggl.com/api/v9/organizations/{organization_id}/groups/{group_id}".to_string()).json(&serde_json::json!([\{"op":"string","path":"string","value":[\{\}]\}]))  .header(CONTENT_TYPE, "application/json")  .send()  .await?  .json()  .await?;    println!("{:#?}", json);  Ok(())}
organization_id integer true Numeric ID of the organization.
group_id integer true Numeric ID of the group.
Body​
items Array of object -
items​
op string -
path string -
value Array of integer -
Returns the result of the requested operations.
failure Array of object -
success Array of object -
failure​
message string -
patch object -
patch​
op string -
path string -
success​
op string -
path string -
Possible error messages:
  • Invalid JSON input
  • Empty or invalid patch operation
  • Empty or invalid patch path
  • Unknown group at organization
  • Too many patches_Too many values per patch_
Forbidden
404​
Invalid group ID.
To be blunt, your API documentation is really confusing and missing key information.
For example:
  • What are the accepted values for op?
  • What are the accepted values for path?
  • There’s also a major contradiction for the value field. The description says it’s an “Array of integer,” but the example shows an “Array of object.” Which one is correct?
    And if value is supposed to be an array of integers, how are we supposed to update string fields, like a group’s name?
Honestly, it feels like this documentation wasn’t reviewed before being published. This makes it extremely difficult for us, as paying customers, to integrate with your service.
