Is there a way to change what entries are suggested when I start typing in the “What have you done” bar?
Basically, I have many tasks with similar names, so when I start typing, a lot of suggestions come up. Many of them are no longer current. Can I change the length of time the suggestions look back? Or can it be disabled altogether?
Searched around in the FAQs and couldn’t find an answer, or similar posts. Thanks in advance.
That’s a great question! Unfortunately, adjusting the lookback period for autocomplete suggestions or disabling them altogether is not currently possible in Toggl Track. There is no setting to control how far back the suggestions reach or to turn them off.
As a workaround, you could consider archiving old projects or tasks that are no longer relevant. This can help reduce the clutter in your suggestions and make it easier to find current entries when typing.
I’ll make sure to pass your feedback about controlling suggestion behavior along to the product team, as it sounds like a useful feature for users managing lots of similar tasks!
