Labour forecasting and planning features?
Searching hasn’t brought up anything related to the subject, so here I am posting my question :slight_smile:
Is there a way to forecast labour availability for the future with toggl track? IE, if I have a staff member that typicall works a balance of support and projects, can I (reasonably) accurately forecast their availability for future projects when their assigned tasks are completed?
Are there any such forecasting or planning features available in either track or plan?
Thanks in advance!
-Pete
I may have been a bit hasty in posting, I’ll go through the approach listed here: Resource Forecasting in Project Management: In-Depth Guide
Yes, but that’s not in Toggl track, unless I’m mistaken. Its Toggl Plan. Would be helpful to have a feature in Toggl Track that allows you to allocate not only total project hours, but projected hours per team member. Then you can report on future month hours allocated to each staff member.
100%. With my team, we always have a portion of time spent on support. I’d love to be able to forecast that based on past trends to then understand how much time is available for projects work.
