Legacy Report Export Option does not preserve previous exported columns
Today I noticed the report export had legacy export options. This is great, as it appears the purpose is to give you an export that will still work with whatever you are using it for. However, it turns out that two columns (Task,Billable) are removed from this export. Even though these columns were not really used, removing them completely invalidates the point of having a “legacy” export option. It will still break things that people are using these reports for, so why did you even bother to give us the legacy export option?
Edit: It appears that perhaps also the ordering of the days switched from ascending to descending. This also breaks the consistency of the report and breaks things that people are using this for.
This would not be such a big deal if we were talking about anything other than a link you labeled as “legacy” export. “Use the Legacy CSV format to ignore table customizations and keep automations working.”
Heya Ben! Can you verify which report you’re attempting these exports on?
Reports > Detailed (This week)
Hey @benmiller
I’ve DM’d you.
Thanks!
