“Projects” Endpoints - PUT Update the data for a project user for a given workspace
https://api.track.toggl.com/api/v9/workspaces/{workspace_id}/project_users/{project_user_id}
Update the data for a project user for a given workspace.
extern crate tokio;extern crate serde_json;use reqwest::{Client};use reqwest::header::{CONTENT_TYPE};#[tokio::main]async fn main() -> Result<(), reqwest::Error> {  let client = Client::new().basic_auth("<email>", "<password>");  let json = client.request(Method::PUT, "https://api.track.toggl.com/api/v9/workspaces/{workspace_id}/project_users/{project_user_id}".to_string()).json(&serde_json::json!(\{"labor_cost":"number","labor_cost_change_mode":"string","manager":"boolean","rate":"number","rate_change_mode":"string"\}))  .header(CONTENT_TYPE, "application/json")  .send()  .await?  .json()  .await?;    println!("{:#?}", json);  Ok(())}
project_user_id integer true Numeric ID of the project user
Body​
labor_cost number Labor cost for this project user
labor_cost_change_mode string Labor cost change mode for this project user. Can be “start-today”, “override-current”, “override-all”
manager boolean Whether the user will be manager of the project
rate number Rate for this project user
rate_change_mode string Rate change mode for this project user. Can be “start-today”, “override-current”, “override-all”
at string When was last modified
gid integer Group ID, legacy field
group_id integer Group ID
id integer Project User ID
labor_cost number null
labor_cost_last_updated string Date for labor cost last updated
manager boolean Whether the user is manager of the project
project_id integer Project ID
rate number null
rate_last_updated string Date for rate last updated
user_id integer User ID
Possible error messages:
  • Workspace not found
  • Missing data
  • Invalid project_id
  • Invalid user_id
