Report issues
Hi all,
I wonder if anyone can help with my reports view. Something has changed over the past week and now all reports are broken, I cant get a view of team tasks any more. Below is an example screenshot for Feb. And its not stacking data correctly or visualising it properly. Its also not victualing the entire month of Feb. This is happening on multiple views and pre built reports for me
I understand you’re experiencing issues with your reports not displaying correctly, with data not stacking properly and not showing the full date range you’re looking at.
Since this appears to be a technical issue affecting multiple report views, I’d recommend trying a few troubleshooting steps:
First, try refreshing your browser page to see if that resolves the display issue. If you’re using a desktop app, you could try closing and reopening it.
You might also check if you’re using the latest version of Toggl Track and your browser. Sometimes updates can affect how reports render.
If the problem persists across multiple reports and views, there may be a display bug that needs investigation. I’d recommend reaching out directly to the Toggl support team with details about what you’re seeing, including the screenshot you mentioned, so they can look into what changed over the past week and help get your reports working properly again.
this is happening world wide…. we can not access the reports since at least a week ago
In the Starter Plan, I only get Stacking by Billable (other options are premium features), and that does seem to be working.
Hey there :blush:
The reports outage should have been resolved late on Monday 2nd March, are you still having difficulties with reports continuously loading?
If so, please let us know :folded_hands:
