Want to send invoices in Toggl Work? You’ll need to have at least one client created first.
That’s where the Team Clients section comes in - a simple place to manage all the clients you work with.
Let’s walk through how it works.
Where to Find Team Clients
You’ll find Team Clients in the same spot as the other Team sections - on the left-hand navigation bar, under your organization name.
Click Team Clients, and you’ll land on a page showing a table with:
All previously added clients and key info like:
Client name
Business address
Business Registry Code
VAT Number
If it’s your first time here, the list will be empty. Let’s fix that.
How to Create a New Client
To create a new client:
Click the “New Team Client” button in the top-right corner (with a little
icon)
A pop-up will open asking for:
Legal Name
Business Address
VAT Number
Fill in the details and click Save
Once saved, the new client will appear in your table - ready to be linked to future invoices.
Editing or Deleting a Client
Need to update or remove a client? Super easy.
Next to each client row, on the far right, you’ll see a three-dot menu:
Click it to either:
Edit the client → this opens the same window as during creation
Delete the client → if you no longer need it
You can update all fields: name, address, registry code, or VAT number at any time.
Pro tip: Make sure your client details are accurate - they’ll appear on every invoice you link them to.
Searching Through Clients
As your list grows, the search bar at the top right of the table becomes super handy.
Type in the client’s name or any keyword to filter the list and find what you need instantly.
What Happens After You Add Clients?
Once your clients are created, you can link them directly to your invoices - just head over to the Invoices section when creating a new invoice, and you’ll see all your Team Clients in the dropdown list.
We cover that process in more detail in this article on creating invoices
TL;DR — Team Clients Recap
Here’s what you can do from this page:
Create, edit, or delete clients
Store key company info like VAT and registry codes
Search easily through long client lists
Use them instantly in invoices
Help & Feedback: In case you need any assistance, reach out in the community. That is also where we’d love to hear your thoughts on Toggl Work - we read all comments and build the product with them in mind.
