“Time entries” Endpoints - POST Time Entries
https://api.track.toggl.com/api/v9/workspaces/{workspace_id}/time_entries
Creates a new workspace Time Entry.
extern crate tokio;extern crate serde_json;use reqwest::{Client};use reqwest::header::{CONTENT_TYPE};#[tokio::main]async fn main() -> Result<(), reqwest::Error> {  let client = Client::new().basic_auth("<email>", "<password>");  let json = client.request(Method::POST, "https://api.track.toggl.com/api/v9/workspaces/{workspace_id}/time_entries".to_string()).json(&serde_json::json!(\{"billable":"boolean","created_with":"string","description":"string","duration":"integer","duronly":"boolean","event_metadata":\{"origin_feature":"string","visible_goals_count":"integer"\},"pid":"integer","project_id":"integer","shared_with_user_ids":[\{\}],"start":"string","start_date":"string","stop":"string","tag_action":"string","tag_ids":[\{\}],"tags":[\{\}],"task_id":"integer","tid":"integer","uid":"integer","user_id":"integer","wid":"integer","workspace_id":"integer"\}))  .header(CONTENT_TYPE, "application/json")  .send()  .await?  .json()  .await?;    println!("{:#?}", json);  Ok(())}
Query​
meta boolean false Should the response contain data for meta entities
Body​
billable boolean Whether the time entry is marked as billable, optional, default false
created_with string Must be provided when creating a time entry and should identify the service/application used to create it
description string Time entry description, optional
duration integer Time entry duration. For running entries should be negative, preferable -1
duronly boolean Deprecated: Used to create a time entry with a duration but without a stop time. This parameter can be ignored.
event_metadata object -
pid integer Project ID, legacy field
project_id integer Project ID, optional
shared_with_user_ids Array of integer List of user IDs to share this time entry with
start string Start time in UTC, required for creation. Format: 2006-01-02T15:04:05Z
start_date string If provided during creation, the date part will take precedence over the date part of “start”. Format: 2006-11-07
stop string Stop time in UTC, can be omitted if it’s still running or created with “duration”. If “stop” and “duration” are provided, values must be consistent (start + duration == stop)
tag_action string Can be “add” or “delete”. Used when updating an existing time entry
tag_ids Array of integer IDs of tags to add/remove
tags Array of string Names of tags to add/remove. If name does not exist as tag, one will be created automatically
task_id integer Task ID, optional
tid integer Task ID, legacy field
uid integer Time Entry creator ID, legacy field
user_id integer Time Entry creator ID, if omitted will use the requester user ID
wid integer Workspace ID, legacy field
workspace_id integer Workspace ID, required
event_metadata​
origin_feature string -
visible_goals_count integer -
A workspace TimeEntry.
at string When was last updated
client_name string Related entities meta fields - if requested
description string null
duronly boolean Used to create a TE with a duration but without a stop time, this field is deprecated for GET endpoints where the value will always be true.
id integer Time Entry ID
permissions Array of string Permission list
project_active boolean -
project_billable boolean -
project_color string -
project_id integer null
project_name string -
shared_with Array of object Indicates who the time entry has been shared with
stop string Stop time in UTC, can be null if it’s still running or created with “duration” and “duronly” fields
tag_ids Array of integer Tag IDs, null if tags were not provided or were later deleted
tags Array of string Tag names, null if tags were not provided or were later deleted
task_id integer null
task_name string -
user_avatar_url string -
user_name string -
shared_with​
accepted boolean -
user_id integer -
user_name string -
