Times format: hh:mm:ss vs. x.x hours
Toggl Track
Topic content
When I open a project, I see the tasks and the time spent on each task. The time used to be shown in the format hh:mm:ss, was then changed to x.x hours, and is now back to hh:mm:ss. Is there a way for me to set the format to x.x hours again?
Related to this: When I go to the reports page, I see there is a mix of formats, both hh:mm:ss at Total Hours, Client and description breakdown and Client destribution, x.x hours at Duration by day and Average Daily Hours (which is in the same visual block as Total Hours). To expand my question: is there a way for me to set the format to x.x hours or hh:mm:ss for all of Toggl Track? The format in the project view is most important to me as I use it daily and now need to convert hh:mm:ss to x.x hours manually, but if you get that working, I can imagine that might be applied in more places.
Hi! Go here to change the duration to decimal format: Toggl Track
Do note, some places in the app are hard-coded to only show hh:mm format. However, most fields will change once you update this setting.
Thanks! I’d been looking for this setting, I have no idea how I managed to miss it.
