Toggl 2.0 Recurring Tasks
Recurring tasks are currently created without a recurring time block. In case we get feedback on it, we can add that functionality; this time we opted for a slightly smaller scope. How this works:
  • Add a date (or dates) to your task
  • Pick a recurrence (daily, weekly, monthly)
  • Task is shown on top of the calendar
  • Drag and drop the tasks to your calendar for time blocking (or don’t)
    • When you delete the time block
  • When you mark the tasks as done they’re removed from their designated spots
I’m not seeing the REPEAT field on my tasks - how else can I create recurring tasks?
Same here, were you able to find a solution?
Hello! When you enter a start date for the task, ensure you’re NOT adding an end date for the task. Then let me know if the Repeat option appears!
Thanks! I see it now. Appreciate the help.
Can we remove the original date from the main recurring task? Right now it shows as if it was past due on my Tasks and Board views because the original date is a couple weeks back. It would be helpful if this either updated to the latest occurrence or if it said something like Recurring instead of showing the From - To dates.
I will have this use case, now im still tracking it else where.
Btw, Is there a way to see the repeated tasks with different dates on board view? I’m coming to toggl focus as toggl track user, and used to track the tasks else where. So seeing the repeated tasks just on the “My Time“ view is still not very intuitive for me.
I can’t see a repeat option. I only picked one date (not from-to) but it still doesn’t show up. Have you got rid of repeating tasks? :frowning:
I also am not seeing the repeat option when setting up tasks. I have followed the steps in the video and have selected only one date.
Update: I found the repeat option. It did not automatically appear in the task settings as suggested. After adding a date (or date range) to the task, Repeat appears as an option in the Add property options.
Can we add specific times to this? For example, repeating the task from 13:00 to 15:00 on every workday. Currently, it just appears as a pinned item for the day without specific time details, requiring manual adjustment.
I love this functionality, but I created this account to request a small tweak to it. Is it possible to make it so that I can see these tasks inside the “Tasks” list - created on the day of recurrence - and not only in the “Timer” / timeline panel? I use it to remind myself to do things by setting up small tasks like “check mail”, “issue invoices”, “send cost invoices to accountant” (a bit of an adhd problem), and not being able to do so inside the tasks list makes it hard for me to use.
Of course - there should be a checkbox for that, making it completely optional.
Thanks guys! Really great job on 2.0
We will share this feedback with the team :slight_smile:
