Hi is it possible to connect Toggl Track with Toggl Focus? same way as it is with Toggl Plan integration, → you know to see your Projects from Toggl Track in Toggl Focus? it is time consuming to put task and time entries twice.
Months have passed and still no answer? Please let me know what did you do with this problem.
I am seeing the potential in toggle focus, but it seems so weird there is no synchronization, while you don’t need register there separately from toggle track
it is strange, that you have this functionality in Toggl Plan, so it means you have very similar lines of code, so I would expect that it is like no brainer for you to just copy paste and implement in Togg Focus.
Hi, I would like to bump this thread and mention that integrations (toggl track and google cal) are make/break features for me. Unless I’m missing something, I don’t think I’ll re-up after my free trial… until these features are added. With those integrations, focus would be ideal for my workflow.
I agree - the ability to sync between Toggl Track and Toggl Focus is an essential feature. I understand the company is in the process of consolidating all of the features into Toggl Focus, but it is still missing key features that are available in the other tools.
Toggl Focus needs:
- Ability to input time like Toggl track where you can add time by dragging a box across the scheduling/calendar to visually show the start/stop time.
- Ability to add past time easily, without having to start/stop a timer to do it.
- Ability to export timesheets + report into PDF.
- Tags working on Tasks (tried to add tags, it checked the box, but never added the tag to my task).
- Time off: Option to add a note or specify what type of time off is being taken.
- Calendar view: Clearer notation for which column is actual vs scheduled time.
- Ability to Archive projects, instead of just deleting them.
- Ability to re-arrange pinned projects.
- Ability to filter projects by current, upcoming, and past.
Please add these soon Toggl Team! I’m excited (and so in need of organization) to use this tool to keep my project, myself, and my team in sync!
Thanks for your feedback! We have shared this with the team.
