https://api.track.toggl.com/api/v9/workspaces/{workspace_id}/track_reminders
Creates a workspace tracking reminder.
- cURL
- Go
- Ruby
- JavaScript
- Python
- Rust
extern crate tokio;extern crate serde_json;use reqwest::{Client};use reqwest::header::{CONTENT_TYPE};#[tokio::main]async fn main() -> Result<(), reqwest::Error> { let client = Client::new().basic_auth("<email>", "<password>"); let json = client.request(Method::POST, "https://api.track.toggl.com/api/v9/workspaces/{workspace_id}/track_reminders".to_string()).json(&serde_json::json!(\{"frequency":"integer","group_ids":[\{\}],"threshold":"number","user_ids":[\{\}]\})) .header(CONTENT_TYPE, "application/json") .send() .await? .json() .await?; println!("{:#?}", json); Ok(())}
Parameters
Path
| workspace_id | integer | true | Numeric ID of the workspace |
Body
| Name | Type | Description |
| frequency | integer | Frequency of the reminder in days, should be either 1 or 7 |
| group_ids | Array of integer | Group IDs to send the reminder to, can be omitted if user_ids is provided |
| threshold | number | Threshold is the number of hours after which the reminder will be sent |
| user_ids | Array of integer | User IDs to send the reminder to, can be omitted if group_ids is provided |
Response
200
| created_at | string | Reminder creation time |
| group_ids | Array of integer | Groups IDs to send the reminder to |
| reminder_id | integer | Reminder ID |
| threshold | integer | Threshold is the number of hours after which the reminder will be sent |
| user_ids | Array of integer | User IDs to send the reminder to |
| workspace_id | integer | Workspace ID |
403
500
