I’ve looked around and not been able to find a way to do this, but it would be great if:
- You could add a member to multiple projects at once
- You could add members to multiple projects before they login
Thank you!
Thank you!
That’s a great idea! Unfortunately, adding members to multiple projects at once or adding members before they login is not currently possible in Toggl. Right now, you’d need to add members to projects individually after they’ve joined your workspace.
As a workaround, you could add all your team members to your workspace first, and then assign them to their respective projects one by one through the project settings.
I’ll make sure to share this feature suggestion with our product team.
