Add user rates as a column in Reports
I have to export this time entry data to an invoicing system and I need each user rate to line up with the other time entry data. Each project varies with different user rates and it would be super helpful to be able to export it straight from Toggl instead of manually adding it later, where I may make mistakes.
The summary area shows the rates in the breakdown, so the information is being calculated, but it would save me an enormous amount of time if it could be exported with each time entry line. I also only upgraded to premium so that I could add user rates per project and be able to export them, so I appreciate Toggl’s future assistance with making this update. Thank you!
