Post Title: Updating time range for existing time sheets
Your Question/Topic: I want timesheets to be Sat-Fri. Our timesheets are currently set up as Mon-Sun. I don’t see a way to update existing timesheets. Even if I discontinue a timesheet and set up a new one, it won’t let me create a new one that overlaps with the discontinued timesheet. It says that that team member already has a timesheet. Is there a way to change my timesheets to shift back 2 days?
To adjust the time period for existing timesheets, you’ll need to delete the current timesheets for the period you want to modify, and then create new ones using the Sat-Fri setup. It’s important to delete the old timesheets, rather than just discontinuing them because the tool won’t allow you to create new timesheets if there’s any overlap in the time periods.
I hope this helps! If you have any further questions, please don’t hesitate to ask—we’re happy to assist.
