I would like the ability to clone dashboards so I don’t have to build another one from scratch. Maybe there’s a way to do that, but I have not discovered it yet.
Many thanks!
Many thanks!
Hi Tim,
Thanks for the suggestion! Currently, there isn’t a built-in feature to clone dashboards. Using the dashboard templates might help with this a bit though.
It is a great idea, and I can definitely see how it would save time when setting up similar dashboards. ![]()
I’ve shared your feedback with the product team for their consideration in future updates. If anything changes or a cloning option becomes available, we’ll be sure to let the community know!
Thanks again for helping us improve Toggl Track—keep the great ideas coming! ![]()
Cheers,
Marie
Thanks for you consideration, Marie. Best regards, Tim
