Countdown timer
I’d love to be able to have a countdown view. I have dedicated hours for each client and want to be able to, at a glance, see how many hours I have left for the week/month.
For example, I have to do 16 hours per week for a client, as I start the timer for that client, I’d like to see those 16hours get smaller. It would be great to see quick stats like this on the timer page too (currently I see the total hours across all clients and % for each client but that isn’t super helpful for me).
Heya Morgan! Have you checked out our Goals feature? I think it might help to come close to what you’re looking for! Time Tracking Goals
Thanks Jake! I hadn’t seen this, it definitely somewhat helps, but improvements to this would be:
  • to see the actual figure of how much time is left
  • ability to assign clients, not just projects
  • it feels a little bit clunky to have its own tab (and only be visible there), this is a key stat that could be on the timer view or in the report page
Gotcha; thank you! I can share this as a feature suggestion to our team!
