Post Title: Is it possible to customize summary report fields?
Your Question/Topic: Is it possible to customize summary report fields on the starter or free plans? Ideally I’d like to download a summary report CSV with these fields: Client, Project, Description, Duration, and Tags.
Helpful Tips for Best Answers:
- Be clear and concise.
- Check if your question has been asked before.
- Be respectful and thank those who help.
Customizing the specific fields included in a Summary Report CSV export is not currently possible in Toggl Track on any plan.
As a workaround, the Detailed Report may be a better fit for your needs. It includes fields like Client, Project, Description, Duration, and Tags, and can be exported as a CSV. You would just need to filter or clean up the data on your end if you only want those specific columns.
You can also explore the Toggl Reports API, which gives you more flexibility to pull exactly the data fields you need and build a custom export. That option is available if you are comfortable working with APIs.
@Support I did try a CSV from the Detailed report, but wasn’t able to find a way to group all Descriptions under their Projects, resulting in a miles-ling CSV. It it possible to group a Detailed report that way?
I’ve never worked with API.
Thank you!
