We have two “required fields” enabled: “Project” and “Description”. I’ve found a co-worker’s entry that are lacking both of these (i.e. entered before we upgraded our Toggl plan, so before these fields were required).
If I edit this entry in the “Reports Detailed” view and try to either enter a description or assign the entry to a project, I get the same error:
”Error: Please fill in all required field(s) to save: “.
So by just exiting a field and trying to set focus to another field, the entry is saved! And since I need to add two missing fields, I am stuck.
