Project/Client/Task Not Empty When Editing Multiple Entries
In the Reports view, when batch-editing time entries, the Project field (Client / Project / Task) is shown as empty—even when all selected entries share the exact same values. This also happens when editing a single entry. I assume this is related to the recent UI changes, but the behavior feels like a bug.
A simple use case:
I often need to update the Task for multiple entries belonging to the same Client / Project. Previously, I could select the entries, click Edit, and immediately see the existing Client and Project, then adjust only the Task as needed.
Now, because the field is blank, I have to manually reselect the full Client / Project / Task structure. This makes the workflow slower and increases the risk of selecting the wrong project.
The new combined Client / Project / Task selector is making daily work more difficult and time-consuming across several parts of the app. Please consider bringing back the three separate fields for Client, Project, and Task.
Hey Samuel,
I think you reached out to us directly too! I’ve reported this to the team already and will get back to you via email :slight_smile:
