Error! Start time year must be between 2006 and 2030
Since last week, I’ve been running into a recurring error message in Toggl that says:
Error! Start time year must be between 2006 and 2030.
This happens whenever I try to start log time using the web browser (Chrome), and it’s been blocking me from tracking my work properly.
Has anyone else experienced this issue, and if so, did you find a fix or workaround? Is this something that needs to be corrected in my settings, or is it a known bug that Toggl support is already addressing?
Thanks in advance for any guidance.
Heya! This is something our team is working on a fix for :slight_smile:
Hi @LittleDog :paw_prints: this should be fixed now, would you mind confirming? :slight_smile:
I ran into the same issues and it is fixed since a day or two. Thanks!!
That was really #yikes :slight_smile:
Hello, the bug is fixed for new entries, however I still get many popup messages Error! Start time year must be between 2006 and 2030 when I open the Toggl Track screen. Can you please fix this as well?
Heya @CHA :waving_hand: can you go down the list of your recently-tracked entries and check to see if any have red sync icons on them?
hello,
yes there are red sync icons. i removed these entries and the problem was solved. thank you
