I think this is a bug, although non-critical.
I often forget to start my timers and find myself having to adjust the start time while the timer is running. When I do this, the start time is always in correct.
I’m on a MacBook Pro with MacOs 15.0.1 and Toggle Track app v10.6.1.
This example shows the sequence to reproduce:
I start a timer at 5:12pm (17:12 in my menu bar)
then I want to back date the start time by 5 minutes, so I click on the timer field, but when it appears the start time says 4:43, instead of 5:12 (incidentally, 4:43 is the start time of a previous session)
then I click away so the time fields are hidden, then click in the time fields a second time - this time the time has corrected itself to 5:12
It’s only minor, except my forgetfulness means that I have to go through this a few times every day .
I have put a video of the steps here
I hope that helps
G
