Faulty metadata output from webhook API
Hey,
while trying out the webhook API, I noticed that the request is giving a faulty metadata output for the action.
If I use the list view and delete more than one entry at a time, the request outputs the action: “updated” instead of ‘deleted’.
If only one time entry is deleted, the metadata is correct.
Since other processes are based on the attribute, it would be great if you could adjust this.
Thanks, Lars
Hi Lars, :raised_hands:
Thanks for bringing this to our attention! It sounds like there’s an issue with the metadata output when deleting multiple entries in the list view. I’ve flagged this with our team to investigate and will let you know once we have an update.
Appreciate your patience and detailed feedback! :toggl-heart:
Hi Lars :raised_hands:
Happy to confirm this has been fixed. Thanks again for reporting! :toggl-heart2: And please do get back here if you see any problems in the future. :toggl-muscle:
Hey Marie,
great news! Thanks a lot! :slight_smile:
