Hi, I want to have my Google Calendar integration active on Toggl Focus but disconnect it from Track, the problem is it seems I have to pick one setting for both apps and I don’t want that, what can I do ?
Hi @Raphael_Auriac ![]()
Considering that you have a single Toggl account across all Toggl products, you use the calendar integration gets enabled on both Track and Focus, but what you can do is choose to not display external calendar events in one of the tools, in this case, in Track:
That way, you won’t see your external calendar events in Track, but they will still be displayed in Focus.
Hope that helps!
