synced calendar with time entries as events so you can compare your calendar with what you actually did (via enabling the toggl calendar in your calendar application)
Heya! If I understand correctly you’d like Toggl time entries to appear in your external calendar?
yes indeed i’d love that!
Thanks! I’d recommend checking out our “iCal” integration for that: iCalendar integration | Toggl Track Knowledge Base
