I don’t see a button or link from the three places Toggl says you can do this from. What am I missing?
If you’re not seeing the import option from any of the three entry points (the top banner, the Import data button in the side navigation, or Settings → Data Import), it’s likely a permissions issue. To run a Toggl Track import, you need permission to view workspace rates and member labor costs in Toggl Track. Without those permissions, the import will not be available to you.
A couple of things worth checking:
- Confirm you are a team admin in Toggl, as admins are the ones who can import data for the whole workspace including team members.
- Check with your Toggl Track workspace owner or admin to ensure your account has the necessary permissions to view rates and labor costs.
If permissions look fine and you still cannot find the import entry points, you can also try accessing it directly through Settings → Data Import from within Toggl.
More detail on how the import works is available here: Importing data from Toggl Plan and Toggl Track to Toggl
