Importing data from Toggl Plan and Toggl Track to Toggl Focus
You can now easily transfer your data from Toggl Plan or Toggl Track into Toggl Focus. This article explains how the importer works and walks you through the available import methods.
How to import data
You can kick off the import from any of these three entry points:
  1. Top banner.
  2. Import data button in the side navigation.
  3. Profile settings → Data Import.
Select the product you would like to import from, your desired workspace(s) and click Import data.
Importing from Toggl Plan
  • Import all time data from Toggl Plan to Toggl Focus.
  • Team admins can import all data for their team, including team members. Users who have not yet used Toggl Focus will receive an invite email.
  • Import projects, tasks, status, teams and team members.
  • Task comments will be imported as a task description.
Importing from Toggl Track
  • All of your Track time entries, up until the first 30-month period with where no time entries have been recorded, will be transferred from Toggl Track to Toggl Focus.
  • Organization admins can import their own and the whole workspace data from Track.
  • Organization members can import their own data, but not team data.
  • Import clients, projects, tasks, status.
  • Time entries in without a linked task become archived tasks in Toggl Focus.
Things to keep in mind
  • This is not a live sync. Changes made later in Toggl Plan or Toggl Track (e.g. edits, deletes, re-assignments) will not reflect in Toggl Focus.
  • Import is available at Workspace level only. You cannot choose specific projects. Everything in the selected workspace is imported.
  • If you cancel during import or start over, previous imports remain in Toggl Focus.
Tried this process a number of times to import my projects and tasks from Toggl Plan - nothing happens even though it says it ran successfully.
Hi! I tried it several times, unfortunately, nothing has been imported.
HI! This should be resolved as of last week. Can you please try again and confirm when you get the chance?
Imported from Toggl Plan but it imported hours for other team members and now I can’t filter reports to just my hours.
Hi, I’m trying to import my Toggle Track data into Focus but no data is imported (even though the message says “Complete”. Only the tags are imported.
Hi Sebastiaan! What elements did you attempt to import?
When I go from Toggl Track to Focus, there is only 1 option “Import data” (it says “Select the data that you would like to import: Toggle Track”). No further selections can be made, so I assume it’s the full data set (time entries, tags, projects, etc.).
Hi,
We’re not able to import our Toggl Plan data into Toggl Focus:
Additional response info:
“job_id”: “d5b88ada-90ff-4986-9c1b-9d37a655366e”,
“workspace_id”: 20915197,
“user_id”: 5413575,
“source_workspace_id”: 94269,
“source_product_id”: 4,
“import_scope”: “full_workspace”,
“progress”: -1,
“created_at”: “2025-10-28T08:01:50.597778Z”,
“updated_at”: “2025-10-28T08:02:22.864998Z”,
“failed_activities”: [
“tasks”
@Support: any further solutions to resolve this issue?
Just tried the import feature, is it true that it’s only possible to import the data within a year?
Hey @Cumino_T, the import picks up all time Toggl Plan data and 6 months of data coming from Toggl Track. Did you only see your data from the past year if you’re importing from Toggl Plan? If you could share a screenshot/screen recording, that would be super helpful.
Hey @sebastiaan, I believe a possibility here is that your time entries were imported as archived tasks in Toggl Focus, since they were not associated to a Task in Toggl Track. You can view archived tasks from Tasks → Archived, let us know if this is the case
Yes, now I see them, but they still do not show up in the Toggle Focus - Calendar (My time) view. In Toggle Track I group/label my time entries by Project (and use tags). How to get this imported/synced from Track to Focus?
Still can not import the data. Can this be fixed?
Hi @cloetensbrecht, thank you for reporting this, I’m checking with our team and will get back to you!
I have tried several times to do the import from Toggl Plan, without succes. All the time, the same error:
We were unable to import some of the following data:
  • Members
Hi all, we’d like to let you know that the import functionality will be paused until Tuesday (9 December) while we fix some ongoing issues. Apologies for any inconvenience caused, we’ll let you know when it’s back up and running!
Hey! Just a heads up, i’ve tried importing my data from toggl track a couple of times but it’s not working
Hello! This should be resolved now; can you try again?
