I am generating my first set of weekly reports to client. The Detailed and Summary reports include a 2nd page that displays “Project - Time Entry”. The column headings are Duration, Amount and Percentage. I want to eliminate this page completely from my reports. How do I do that? Thanks!
Hi Barb,
Thank you for reaching out!
If you’re looking for a report that focuses on analytics only, we recommend using our Analytics section. In this section, you can create custom dashboards with full control over the charts and data parameters. Once you’ve built your desired dashboard, you can easily export it and share it with your clients.
I suggest checking out this helpful article on how to create a dashboard in the Analytics section: Overview of Analytics.
I hope this helps! If you have any more questions, don’t hesitate to reach out.
All the best,
Carmen
