How to Check if a Time Entry Was Billed
Hi everyone! :blush:
I hope you’re all doing great!
I’m trying to figure out how to determine if a specific time entry has been billed. Are there any tools, features, or reports you recommend that could help with tracking this? I’d love any insights or tips you can share!
Thanks in advance for your help
Hi there,
The most popular method for marking billed hours is by using Tags.
To make it happen add a “billed” or “invoiced” tag to whichever time entry you just invoiced. Tagging multiple entries isn’t a problem either because you can bulk edit data on the Detailed Report.
Do let me know if you need any further help with this.
Hi, thank you for your response.
I appreciate your suggestion, but the challenge with using tags is that we cannot filter out all unbilled entries if other tags are in use. Currently, the toggle filter only allows us to filter entries with no tags or entries that have a specific tag. We are unable to filter entries that lack the “billed” tag.
Please let me know if you have any ideas for a workaround.
I came here for the same question. I’d like to see what I have unbilled for a project, client, or across all clients.
It seems like a flag for “billed” when you generate an invoice would have been built into the product.
Best I can figure out is that I could add my own “unbilled” tag to all entries. Then remove it a tag as “billed” when I invoice.
Anyone else have thoughts on this?
Same problem here. A problem is also that autocomplete could mark an entry as billed even though it’s not.
Any solutions to this?
You use a ‘Invoiced’ tag and under detailed view of project you select a filter for ‘Is Billable’ and Tag = Is Not ‘Invoiced’
