Individual entry with title + multiline detailed description for actually useful reporting
I have another great suggestion🥳
I am doing client work and track the work I am doing. Most of the work is done without the client knowing about it (maintenance, updates, taking care of website + infrastructure in the background). I want to send the client a report every quarter (or maybe monthly). I even consider giving live access to a filtered report.
However, it’s difficult to describe what I did. The current very short description of an entry is not made for this.
I would be so cool to have a global setting where I can select the mode:
  1. simple mode (as it is right now)
  2. detailed mode
Even better, make it in a smart way without me having to pick a mode. Becaus when offering two modes you would need to do checks when a user switches the mode in the settings.
What is the detailed mode?
It brings up an additional field for each entry. Instead of having only this one line of text for the description it has a title (maybe up to 255 char) and a detailed description (without an actual limit).
Let’s say I am working on a problem on 4 different days. Every day I add a time entry. Every day I pick the very same entry, which has a title and a description.
Title: Fixing Weglot problems after updating plugin
Details: Here can go a more detailed description that explains to the client in the report what was going and and on top of that is helpful for myself. This way I can completely rely on Toggl as my single source. Everythign I did for the client will be logged in there in a way that I can understand an entire year even if I go over the report.
It’s incredibly powerful and gives options to use Toggl on a different level.
All because I am able to describe each entry in more detail.
This way I could have actually useful report. All automatic right out of Toggl.
This would be amazing! The app could predict the mode based on how many characters you start entering or based on previous activity. :+1: for this request.
Thank you for sharing such a detailed feature request! It sounds great. We are working towards incorporating smart features in the future, and this would fit right in. :slightly_smiling_face:
While I can’t make any promises, I can assure you that this has been noted down and shared with the product team for consideration in future development.
Please share any other suggestions you may have! We truly appreciate it. Suggestions from users help us build a better experience in the future. :slight_smile:
Thanks for your reply. The simple mode and detailed mode was more of an illustration, it’s technically more difficult to implement it than having a single mode (also better UX). Interested to see what you can come up with a “smart mode” (could be everything these days).
The fundament of my idea would probably be simply another field (details) of each entry. If it’s empty then you simply don’t show it to get the same result as it is now. But we as users have the choice in that case.
The reports must be amazing. Reports with manual data with real value to a client without much of an additional effort in tracking.
I created another post that is related to this. It does not seem that there is much interest in my suggested use case, i.e. have a short title + multiline detailed description of each tracking entry instead of only a short description.
Therefore I created another post to discuss another solution to this.
If we cannot have what I came up with, maybe we can just use that single description field and add context directly into it. For instance it’s possible to come up with some naming convention myself, e.g.
Description:
“Short title of tracking entry 𑗅 Longer description for more details added into the same field after the pipe separater character for better understanding what this is about”
But to be able to read it later on, it would require at least to be able to wrap the content in the “description” column in the reports. The new reporting is still in beta, so maybe that’s a good chance to get that in now.
Hi @markus thank you for sharing these suggestions. At this time, it is not a matter of interested, rarther capacity :sweat_smile: We’re working on major improvements to the Track app and a big project yet to be made public to all our users. Rest assured that our product team does see your ideas and are very grateful you are sharing them :raising_hands: Hope to meet your needs in the near future.
My suggestion is to fix the BASIC requirement. As an IT Director, developer AND someone who’s worked in the creative and advertising industry for a very long time, time entry + good notes is essential. Get your product manager on the line. Buy him/her/they a triple latte and get this thing moved to number one on the list. Pause integrations, pause introduction to AI analytics, pause new reporting. This needs to be 1 on the list.
Thanks for the support / vote on this! Good to see someone else sees it as well like me
I still see myself constantly writing 3 lines of text into that tiny field to document the task I am doing. I still don’t understand from a product point of view, usability, and even technical implementation why this idea does not get any love at all. It’s small and essential and can even win over new customers
I’m trying to figure out how to view/edit multi-lines of my Descriptions. This Toggle Track has been looking like an attractive upgrade from my current time tracking software, but the if I can’t see/enter my Time Entry Descriptions in multiple lines that gives me serious pause.
Thanks for commenting, from my experience so far this will never be considered unfortunately. It seems like such a gigantic good upgrade, and from a technical point of view it seems not to be too difficult for implementing it (settings page, database, UX, include in export).
No idea why it’s not getting any traction unfortunately
